Author Topic: Waste ATF on stock unmodified beckett?  (Read 62298 times)
Blaine
« on: December 25, 2024, 10:28:31 pm »
I’m sure the ATF would need to be pre-heated, but has anyone used a beckett without doing a siphon nozzle conversion? If so, what modifications if any.
Thanks, Blaine
Re: Waste ATF on stock unmodified beckett?
« Reply #1 on: December 29, 2024, 05:11:21 pm »
Yes, I used to run a pressure system.  Basically everything stock with the exception of the heater block to heat the oil before it gets to the nozzle.  But if you are going through that work, would highly recommend a siphon conversion.
Here is my pressure system:
https://wasteoilheaterforum.com/index.php?topic=36.msg139#msg139
Blaine
« Reply #2 on: January 19, 2025, 11:03:19 pm »
 I was asking for a friend. He was trying to join this forum, but i think he never received a confirmation to join the group.
