Author Topic: Replacement insulation for inside my Blackgold heater cabinet  (Read 58589 times)
jperloff
Hello,
I am rebuilding an old 1989 Blackgold heater which has a newer Energylogic burner and pump that the previous owner installed.  I want to replace the original insulation in the cabinet that is on the burner end of the unit inside the cabinet.  It is a thin insulation with foil that faces the burn chamber.  The insulation against the inside of the burn chamber wall is very close to the burn chamber and is exposed to high heat. Do you guys have a recommendation on a good replacement insulation?
Jonny
