heat exchanger, aqua-stat, expansion, a couple air bleeders, and pump I have two ball valve for water lines in and up. water supply for closed loop system you'll need water valve, check valve, pressure valve. does your boiler have a pressure release valve?
are you planning heating your domestic hot water?
what kind of boiler did you buy?
welcome to the site.
