Author Topic: Hello  (Read 54457 times)
Michael
Hello
« on: February 03, 2011, 01:17:15 am »
Currently have a large wood burner in my workshop but am considering possibilities of a diy waste oil burning heater. I am hoping to convert my existing stove.
Mike
Re: Hello
« Reply #1 on: February 03, 2011, 02:50:04 pm »
welcome, its very easy to have a pipe going in drip feeding oil into an old steel pan, there done it !!!
Michael
Re: Hello
« Reply #2 on: February 04, 2011, 12:57:34 am »
I used to own a boat with a Reflex stove. This used the boat fuel, red diesel, through a control valve to control the flow. It was just what you describe, a drip feed. I used to light it with meths or firelighters.
I thought the same sort of arrangement might be OK with waste oil but thought there might be a knack getting it to burn cleanly.
Mike
Re: Hello
« Reply #3 on: February 05, 2011, 03:05:31 am »
not really, all you need is the right amount of air and it does the rest on its own, normally when your burning oil and your getting lots of smoke it cause you aint getting enough air into the mix, i use a small hairdryer to blow extra air in, or an old vacuum cleamer on blow, you'll need a dimmer rheostat to control the flow of air
