Author Topic: let the fun begin  (Read 689592 times)
Re: let the fun begin
« Reply #75 on: September 20, 2013, 06:40:57 pm »
An update to the 2012/2013 heating season. Total hours the burner fired was 2957 hours and used a total of 950 gallons of oil for the season. That's 3.11 gph. I turn up the heat in the boiler this year. Last years use was 2.17 gph.
 It's getting time to think heating again.
« Last Edit: September 23, 2013, 09:59:19 am by doug »
« Reply #76 on: December 18, 2013, 08:39:52 pm »
With over 6000 hours run time on the burner I had some trouble today. When the aquastat would call for heat the digital temp controller came on, but the temp only raised to 120*. Replaced the heat cartridge and now everything is working again. Also got to clean the nozzle while it was down.
« Reply #77 on: December 18, 2013, 09:07:56 pm »
Not too bad of a fix.  Did the old cartridge come out allright?
« Reply #78 on: December 18, 2013, 09:30:39 pm »
Once you get the blast tube off it's easy to get at. The cartridge just pulled out.
Just checked the burner out and it's back doing what it did before. Tomarrow I'll have to find a relay and change that.
« Last Edit: December 18, 2013, 09:32:10 pm by doug »
« Reply #79 on: July 30, 2014, 08:19:35 pm »
 A little update on my 2013/2014 heating season. Here in Southern Michigan it was the coldest winter I ever knew living here all my life and it seemed like spring was long in getting here also. This season the burner ran for 3547 hours an used a new high of burning 1100 gallons. Hoping for a milder up coming season.
« Reply #80 on: April 28, 2015, 09:19:02 pm »
Get your free heat where ever you can. Scored 550 gallons of free fuel oil this weekend. All I had to do was pump it from their tank. Looks like some of next season we'll be heating with fuel oil.
« Last Edit: April 30, 2015, 07:41:46 pm by doug »
« Reply #81 on: April 30, 2015, 09:37:30 pm »
Hello Doug.  Good to hear from you again!
Wow, nice score!  It isnt quite cool as burning oil, but I guess free heat is free heat  ;)
Hope all is well!
« Reply #82 on: May 01, 2015, 08:16:37 pm »
Russ,
It's getting tougher to find the volume of waste oil that I use. The fuel oil will help me get a head on the amount waste oil I'll have on hand. Burners got 11,000 hours and has been clicking them off with no problems.
superduty_59
« Reply #83 on: December 16, 2016, 10:32:48 am »
Doug you have the almost exact setup that I'm trying to build. Very nice! You were already ahead of the game reusing probably a lot of the existing Wood boiler system. I couldn't tell from you pics your suppy and return lines. You probaby have the buried insulated 1" pex lines going from your boiler to your house. I priced 50' and it will be close to $500. Do you have any more pics of you setup (expansion tank, aquastats, valves, ect)? Thanks
superduty_59
« Reply #84 on: December 16, 2016, 10:33:53 am »
How about an update on the 2016/2017 heating season? Thanks Doug!
James
« Reply #85 on: December 16, 2016, 06:34:02 pm »
james,
 my set up is a blend of a lot of other peoples hard work. the buried 1" is from a shelled corn fed boiler (similar to a wood boiler). supply lines are on top with the expansion tank and air bleeder valve, supply on lower side. I have 2 more air bleeder in the basement where the line has high spots and one bleeder in the shop at the heat exchanger. sorry I don't have any more pictures of the set up.
one thing I would do different would be to raise the boiler higher off the floor at least 8" or more. that would make it easier to clean.
« Last Edit: December 16, 2016, 08:09:03 pm by doug »
« Reply #86 on: December 16, 2016, 06:50:22 pm »
James
14201 hours of run time on the system and still going strong.
superduty_59
« Reply #87 on: December 17, 2016, 12:01:27 pm »
Good to hear Doug! I am just a curious person by nature and have lots of questions.  ;D Just tell me when you've had enough with my questions! ;) Speaking of how many hours yours has produced heat, what kind of hour meter do you have installed? I assume it only clicks off when the burner is called for with the relay?  Thanks
« Reply #88 on: December 17, 2016, 07:43:59 pm »
timer was an ebay find. when the burner runs so does the clock.
superduty_59
« Reply #89 on: December 18, 2016, 07:56:30 am »
I have a few analog hour meters from some generators that was updated. I could use those but would not start at 0 unless I could figure out how to roll them back to 0. Thanks Doug
