Waste Oil Heater => Waste Motor Oil => Topic started by: surplus 6 on March 31, 2013, 06:21:51 pm
I like the idea/simplicity of the roger sanders set up, but with only an area of 10 x 16 feet in my w/shop would one of those be to much (better insulation in hand), or would it be easy to scale down into a smaller package say a lpg/calour/propane type gas bottle like people make wood burners out of?
I am new to this, but at 47 and worked on the tools most of my working life I have a modderate to fair skill level, a brother who welds and a knowledge of where to get bits and bobs from and how they can work together, what I don't have is a lot of money. any idea's suggestions most appreciated.
many thanks
tony
I've always like this design over the sanders style heater. May be it's because I can see the flame in the secondary heater tube. He has four videos showing how he made his heater and some of the troubles he had during the assemble.
http://www.youtube.com/watch?v=4baNb1LD9bU.
Tony,
Have you deceided on what type of heater your going to build?
A 16' x 10' building should be easy to heat.
I have an empty lpg/gas bottle now so I'm in the process of gathering some bits and pieces and going to do a sanders style drip feed heater, as you say 10 x 16 shouldn't be to hard to heat/keep warm.
Tony,
I ran across this sanders heater today. I didn't know if you had seen it.
http://www.youtube.com/watch?v=eWJcRmketlE
thanks for that, I hadn't seen that before
