Author Topic: Chinese quality update  (Read 7748 times)
jettyhouse
  • Guest
« on: March 21, 2010, 02:37:51 am »
I have installed the sky burner and so far(1 month)I am impressed.It was dooable with not a huge effort I had to modify a wood fired boiler run pipes from outbuilding but just in time for tasmanias winter I have enough hot water to heat a very large house.The fuel consumption seems high but I havn't worked how many KWs its putting out.
Re: Chinese quality update
« Reply #1 on: April 04, 2010, 09:24:47 pm »
Good to hear it is working out for you.  Do you have some pictures of the burner and your setup you could post?  I would be interested in seeing what you are working with.
Yea, a good source of fuel is definitely needed if you are going to be running the heater a lot!
Later...
