Author Topic: Welcome from Dwaynes Garage  (Read 5866 times)
Dwaynesgarage
« on: May 01, 2021, 07:43:09 pm »
Hi Y'all, I am Dwayne and I have recently installed a Clean Energy 140 furnace. Its a used unit with 1000 hours and this is my first kick at the can with waste oil heat. I don't really know what to expect from it and I have a couple of questions for the more experienced.
I have what looks to be a healthy flame, fires right up with little to no smoke while running. But..
I have unburnt fuel in the combustion chamber after running and smoke up the stack after shutting down.
Is this normal?
I have the settings for air flow and pressure set to factory and 1 psi of oil pressure.
Any help would be greatly appreciated.
Re: Welcome from Dwaynes Garage
« Reply #1 on: May 02, 2021, 11:46:57 am »
Welcome Dwatbesgarage!
Is this happening after running the heater for a longer period of time?  Like at least a half hour?  It takes a while to warm up the inside of the heater and get everything up to temp so all of the oil burns.  Be sure everything is getting good and hot.  I would think as long as everything is good and hot it shouldnt smoke after shutting down.
« Reply #2 on: May 07, 2021, 09:41:25 am »
Is this normal?
You should have no smoke coming out the stack. So lets start with some basic stuff first.
What is your elevation ?
Firebox clean ?
Clean nozzle ?
12-14 psi for air ?
Clean combustion air blower ?
Flame should be 1/2-3/4 to the target.
Flame should have a bright yellow body with orange tips.
Dwaynesgarage
« Reply #3 on: May 13, 2021, 07:45:15 pm »
Thanks guys for the quick responses. I have the furnace now working better.
After a thorough cleaning of the burner, nozzle and combustion chamber there was little difference so I thought that the only thing it could be was fuel.
My waste oil is 95% full synthetic. I read that some furnaces don't like that so I lowered the flash point with a little #2 fuel oil (10% or so) and things seem to be ok.
What are your thoughts?
« Reply #4 on: May 13, 2021, 08:07:55 pm »
Synthetics burn fine but the issue is getting them to ignite. If it fires right up then it is fine. Was all the ash a fine white-tan powder ?
