Author Topic: Heated oil line  (Read 4203 times)
liam
Heated oil line
« on: September 07, 2020, 04:39:24 am »
Hey guys! Can someone point me in some directions? I want some advice here. I use veggie oil that doesn't flow at the room temperature. how do you use it? How do you preheat it? I'm thinking to use some defrosting wire to heat the pipe so that the pump will deliver oil to the burner. Any advice or links will be appreciated! I need to heat the line because of the oil that stays there between the burning time...
