Author Topic: CK burner kit  (Read 7415 times)
acarter
CK burner kit
« on: February 16, 2020, 09:59:09 am »
About 3 years ago I bought a used Clean Burn burner and triad boiler and set myself up for waste oil. After 2 seasons of messing with the old Clean Burn setup I decided to give the CK Burner kit a try with a new Beckett burner. I put it together and set it up this past summer, it's been running since October and the few times I've had issues it has been air compressor related, the burner itself has been flawless. The Clean Burn burner was an almost daily "tuning" of the oil and air pressures to get it to burn right and there was always something wrong with it (which was most likely age related). The CK burner has been a "set it and forget it" machine.
I tried a few tips and ended up with the 1gpm nozzle to get more heat for a large boiler. 12 psi seems to be the happy spot for easy lighting and decent flame size. I have an air regulator (set at 40psi) inline before the reg on the burner itself, this prevents any fluctuation in air pressure (from the air comp. cycling) at the primary burner reg. So once I set got done the initial tuning in the fall I haven't touched the air pressure since.
About once a month I clean out the lower chamber of the boiler and get about a coffee cup of very light ash, much better than the old burner.
I also want to say that the few times I have had a question about the system during setup or afterwards Craig from CK was very quick to respond and very helpful.
Re: CK burner kit
« Reply #1 on: February 16, 2020, 06:04:55 pm »
  I too like dealing with Craig. Always quick to respond and always helpful.
Re: CK burner kit
« Reply #2 on: February 18, 2020, 01:23:51 pm »
Nice looking setup.  CK is a very good way to go!
