Author Topic: Small, Multifuel, Heater. Will run on all solid and liquid fuels. £90 inc P&P.  (Read 7573 times)
John_Oil
https://youtu.be/DSwxdSQoTEI
https://youtu.be/QflBNY3YVhYP
Photos are of my personal heater. The item for sale will be newly built and unused.
Made from stainless steel components, therefore light weight. (You don't have to be King Kong to lift it)
Basic weight, solid fuel configuration: 1.24kg.
With oil burner adaptor: 1.90kg
Dimensions: Height when erected: 46cm
Grill/open fire: 23cm
Diameter Max: 17cm
Flue Dia: 7.2cm
Small, Multi Fuel, Heater/Stove. Will run on solid, liquid and LPG.fuels.. loves waste oil, both petroleum and vegetable based. Basically it will run on anything that burns. I haven't tried petrol. Too scared and so should you be!!
Condition is New (Homemade). Ideal for emergencies heating, camping, preppers etc.,etc.
When operating at optimum temperature, the omissions are virtually smokeless. Running very hot, yes it will belch smoke. The burn is very efficient.
This apparatus is highly unconventional, to say the least.
What do most conventional fires have in common? The air entering the fire is cold! A basic inefficiency right there!
y stoves etc. have been a project spanning over 10 years. These stoves are tried and tested, so you won't be part of the test program.
I have used K.I.S. Kept it simple. Parts are readily available, in the unlikely event replacements are needed.
Warning: The stove must NEVER be left unattended at anytime, when burning liquid fuel. Read and digest thoughely, the enclosed operating instructions.
I TAKE NO RESPONSIBILITY FOR ANY DAMAGE TO PROPERTY OR INJURY TO PERSONS, WHEN OPERATING OR NEAR THIS DEVICE.
USE AT YOUR OWN RISK.
The flue is made from 7cm dia food tins, of the stacker type.
Can be used as heat source, cooker, fire pit, grill etc, when the operating with the top removed. I would not recommend grilling, when burning dirty waste oil. Will handle fuel with high, suspended moisture content also without problem.
Max, probe temperature readings at door level have been for solid fuel, dry briquettes, 650 degs C. Waste oil, up to 950 degs C.
I firmly believe this type stove, is the most versatile piece of kit, in one package I have seen Prove me wrong.
The item you are bidding on, consists of:
- Outer Casing.
- Burner Can
- Upper portion.
- Oil/Liquid Burner adaptor
- All fittings for enclosed stove and open fire mode.
- First stage of flue. (Standard 7cm dia food tin).
The oil burning application has a patent GB2512417B
https://worldwide.espacenet.com/patent/search?q=pn%3DGB2512417A
Dispatched with Royal Mail 2nd Class.
Video's operating in all modes.
https://youtu.be/FxAkOjVyQp8
https://youtu.be/LFjRyfeffQA
https://youtu.be/Ksa-Dq0ZAco
https://youtu.be/fHk4hoqqkzw
https://youtu.be/OPFgIA6k-rw
Please Note: Advertised elsewhere, therefore this auction may terminate early.
Will post overseas, at buyers expense. Please contact me before nuying and I will then give you a price.
WILL ACCEPT A RETURN, For any reason, within 10 days of receipt.Buyer pays for return postage
« Last Edit: May 07, 2020, 04:07:50 am by John_Oil »
