Author Topic: energylogic fuel pump  (Read 9813 times)
Brad
« on: January 17, 2019, 04:16:55 pm »
Hello, I'm hoping someone can tell me if there is a fuel pump equivalent to the the pump used on a Energylogic 200H. Only the pump, nothing else, not the motor, fittings, or gauges. I know their pumps are proprietary and set to a certain delivery and psi. A used Energylogic pump would work too.
Re: energylogic fuel pump
« Reply #1 on: January 21, 2019, 09:43:04 pm »
That is a tricky one Brad.  The only pump I have ever come across for waste oil metering use is the Suntec A2RA-7710.  Do you think it is possible to retrofit something like this?
There are some people out here with some good knowledge with commercial heaters that will hopefully see your message and have some ideas.
Good luck!
« Reply #2 on: January 23, 2019, 12:22:01 am »
With a metered pump the speed of the motor determines the volume and PSI means little with this type of system. What are you trying to accomplish ?
Brad
« Reply #3 on: January 23, 2019, 08:03:23 pm »
I want to replace the pump on an energylogic unit.
« Reply #4 on: January 23, 2019, 10:38:56 pm »
You can buy a new pump head that includes fittings, gauges and lines for about $240. This way there is no screwing around and just slap it on and go.
