Author Topic: Clean burn 1750 no air pressure  (Read 7211 times)
gmgbo
« on: September 28, 2018, 09:47:51 am »
I have a clean burn 1750 and I am not getting any air pressure.  I cracked the line where it goes in and I have air.  The unit will not run, or even try to start.   What do you think?
Re: Clean burn 1750 no air pressure
« Reply #1 on: September 28, 2018, 09:08:59 pm »
Do you have a minimum of 30 psi of air going to the burner ?
What happens when you screw down the air regulator ?
CBTech
« Reply #2 on: October 27, 2018, 05:19:11 pm »
It should at least try to start even if it doesn't have air pressure. Often times, I see the air solenoid nucleus corroded and unable to open due to moisture in the air line. If the burner does absolutely nothing, you may have other issues in addition to no air.
