Author Topic: Lenox furnace Beckett afg conversion  (Read 9229 times)
marvelouzone
« on: November 21, 2016, 11:27:05 pm »
I have a lenox furnace, with becket afg, I was wondering whats the cheapest and quickest setup I can do to burn waste oil, just switched to bigger shop, funds are low, and it'd getting cold.. I know a pressure system is the cheapest, what I was wondering is do I still have to change to another nozzle? and my off topic question is it ok to put 90 degree bend in exhaust flue?
marvelouzone
Re: Lenox furnace Beckett afg conversion
« Reply #1 on: November 22, 2016, 07:29:45 pm »
bump!! anyone have any recommendations
« Reply #2 on: November 25, 2016, 10:54:36 pm »
Greetings marvelouzone!
Check out my conversion of a Lenox furnace:
http://wasteoilheaterforum.com/index.php?topic=36.0
I started out with a pressure system myself.  I would really recommend a siphon system if at all possible.  Even with a pressure system you will need to heat the oil somehow.  I'd rather see you spend your time and resources on a siphon system.
And here is the siphon system I am running today:
http://wasteoilheaterforum.com/index.php?topic=208.0
I have a 90 degree bend in my exhaust and it is working fine.
Good luck in your adventure!
