Author Topic: synthetic mix 50/50?  (Read 8761 times)
jperloff
« on: September 15, 2016, 06:29:57 am »
Hello,
I have a Energylogic 200btu heater that came with the barn on my property.  I used it all last year with no issues.  I have been getting more and more synthetic oil from my friends and co-worker.  Energylogic recommends cutting synthetic with 50/50 of either diesel, used trans fluid, or conventional motor oil.  I have a lot of used hydraulic oil from the test machines at work getting changed.  Do you know if my heater will burn OK using a 50/50 mix of the used hydraulic oil and used synthetic motor oil?
Thanks in advance for any info,
jonny
Re: synthetic mix 50/50?
« Reply #1 on: September 17, 2016, 10:41:59 pm »
Hydraulic oil will not help. You are going to have to mix it since there is no way to adjust preheat temp on a EnergyLogic.
jperloff
« Reply #2 on: November 02, 2016, 11:40:46 am »
ok thanks for the information.
