Author Topic: Help needed with set up.  (Read 13801 times)
meer
« on: April 20, 2016, 03:08:59 pm »
Hello everyone,  nice to be posting here.
I'm planning to set up heavy fuel burner to run waste oil.
Waste oil is known to damage the burner heater and the pump, so i intend to use this filter from guiliani anello ( FOEX25 Mod.: 7050103M )
http://www.wattsindustries.com/images1/23/pdf/63-0020-Filtri_autopulenti_speciali-Special_self-cleaning_filters.pdf
Any advice, ideas?
Thanks in advance!
bmu916
Re: Help needed with set up.
« Reply #1 on: April 20, 2016, 04:57:29 pm »
Hey.
U can never clean the waste oil whit an regular filter like that. U going to Destroy the burner pump.
U need to use an oil separator.
Those filters are made to remove big stuff.
http://www.alfalaval.com/products/separation/centrifugal-separators/separators/
meer
« Reply #2 on: April 21, 2016, 01:31:05 am »
Hey.
Hey BMU, thanks for reply.
I saw the video for the oil seperator you're using in the other thread.  It looks pretty expensive.
I'm going to be running a 25 kg burner ( unlike your 50 kg burner ).  So if you have any idea where I can get something smaller, would really appreciate it.
bmu916
« Reply #3 on: April 21, 2016, 04:31:52 pm »
Yea, that one is  expensive and hard to find, Bigger ones is easier to find. The one im using is from an old ship.
Here is new ones and not so expensive. I dont know if thay clean as good? But its mutch better than a regular filter.
http://www.wvodesigns.com/raw-power-centrifuge.html
http://www.pabiodieselsupply.com/
meer
« Reply #4 on: April 22, 2016, 01:36:58 am »
Hello Sir, thank you again for the reply.  These are real interesting sites.  If you know any more similar sites, please keep them coming  :)
However, the filter I mentioned in my initial post is actually a magnetic filter.  Please see below specifications:
Quote
TECHNICAL AND OPERATION
FEATURES
This kind of filter is suitable for "wasted oil" filtering, which
is  to  be  used  as  fuel  for  burners  properly  studied  for  this
particular function.
The  particular  features  of  this  filter,  the  high  adaptability
and  the  safe  reliability    confirmed  by  several  years
experience, allow to fit this filter to all equipments which use
wasted oil.
Made of simple and solid construction, this filter forces the
oil  to  follow  a  particular  circuit,  which  we  underline  the
characteristics of:
1. Filtration made through one strainer filter ; decantation of
eventual water traces.
2. Magnetic filtration  through one filter n.1 which allows one
perfect  separation  of  all  ferrous  impurities    conteined  in
the oil.
3. Mechanical filtration through one lamellar filter (filter n.2)
which allows the final filtration of all impurities.
The cleaning of this filter is carried out by simply turning
the  hand  wheel  placed  outside  on  the  filter,  even  if  the
plant  is  in  function.This  characteristic  offers  economic
and  practical  advantages.  Therefore,  one  electrical
heater constantly connected with the electronic control of
the temperature, keeps the oil fluid for an easier filtration.
Also, I actually checked with the pump manufacturer and burner manufacturer, and they said it is okay.  However, the heating temperature will need to be set at 60°C.
I attached pics of filter specifications.
bmu916
« Reply #5 on: April 25, 2016, 11:15:46 am »
Okej.
Try it?
meer
« Reply #6 on: April 25, 2016, 11:31:09 am »
Okej.
Try it?
No, sir, but I will definitely update you when I do.  It'll be at least two months till I get the burner, etc.
However, the centrifuge sites you've posted have really grabbed my interest.  I will be getting into that in the future, buying a centrfiuge and working on oil.
bmu916
« Reply #7 on: April 26, 2016, 11:25:08 am »
Its not easy to burn waste oil. Same as burning heavy fuel oil. It takes a lot of TLC to make it work. But when it works, its great!
meer
« Reply #8 on: April 26, 2016, 12:49:19 pm »
To be honest, this is my first time.
Over here, they burn the waste oil straight without filtering, which is good for the traders who are selling the pumps :)
BTW, do you only work on Bentone burners ( GREAT burners very popular here ) or do you also work on other brands like weishaupt, riello, baltur, etc...?
