Author Topic: Need help with a new to me waste oil rig  (Read 15933 times)
m37guy
« on: October 19, 2015, 07:53:12 pm »
I'm the new owner of a 1990 fornax waste oil heater for my garage. got her all hooked up and cleaned and ready to fire. She lit for a few seconds then ran out of oil. I found oil dripping from one of the regulators by the preheated. the rubble inner was ripped. I attached some pics. I need to know where i can buy one of these or if there is a better option on the market. Located in Central NH.
Thanks for the help guys
Re: Need help with a new to me waste oil rig
« Reply #1 on: October 23, 2015, 03:27:58 pm »
Welcome to the forum. I'd try looking at Granger first. http://www.grainger.com/content/general-catalog
Or at Centralohioheaters. http://www.centralohioheaters.com/All-other-brands.html
Got any more pic of your burner?
« Last Edit: October 23, 2015, 03:35:20 pm by doug »
m37guy
« Reply #2 on: October 25, 2015, 03:09:14 pm »
So i found out the info on the pressure reg
thats not a issue now...
I get her fired up and then she shuts down in 30ish seconds..
I put in a new CAD sensor but the #'s are not the exact same.
the C554a are the same but the 1463 (old) was different on the new one
I cleaned it 4 times already but she still runs so so then shuts down.
Also i just broke the plug off of the pre heater... will this work as a replacement?
http://www.econoheat.com/parts/snap-switch-new-style/
Please help before i out it on Craig's List so someone else can have fun with it
m37guy
« Reply #3 on: October 25, 2015, 03:11:37 pm »
pic
m37guy
« Reply #4 on: October 25, 2015, 03:12:34 pm »
another one
« Reply #5 on: October 27, 2015, 06:47:33 pm »
Was your burner trying to fire for 30 seconds or did you have a flame for 30 seconds?
m37guy
« Reply #6 on: October 27, 2015, 06:54:55 pm »
it was running for 30-45 seconds maybe then shuts off...
wait a 45ish then push the red button and she fires up again for 30-45 then shuts off again
« Reply #7 on: October 28, 2015, 07:38:21 pm »
I would replace the CAD sensor with the correct part. Sounds like the primary safety is not getting the proper signal from the CAD sensor and shutting the burner off.
« Last Edit: October 28, 2015, 07:40:10 pm by doug »
m37guy
« Reply #8 on: October 28, 2015, 07:53:51 pm »
will grangers or what place should have it or should i order it on line?
i got the other one (wrong #'s from HD, thats all they had)
Thanks for the help so far Doug i was starting to wounder if anyone was on here!
m37guy
« Reply #9 on: October 29, 2015, 07:48:23 pm »
I stopped by F W Webb today and those guys are great!
They hooked me up with the right parts i needed and even had a good personality!
I got her running strong for a solid 10 minutes then i shut her down for a few to cool off and then fired her back up again and everything works like it should.
Doug thanks again for the help, like i said i'm new to oil heaters not to mention waste oil ones but i think im good to o now
« Reply #10 on: October 30, 2015, 09:14:08 pm »
Your welcome. Maybe down the road you can return the favor to some else with burner problems. In the last five years I've had a lot of help from a lot of people. That's why we're here, it's to help each other. I just don't stop in here as much as I use to. Glad you have your burner running.
« Last Edit: October 30, 2015, 09:17:05 pm by doug »
