Author Topic: Waste oil for my maple syrup evaporator?  (Read 9248 times)
psparr
« on: November 23, 2014, 08:30:25 pm »
HI. First time here. I just had a brain storm, or a brain fart and need some help.
I make maple syrup on a homemade wood fired evaporator and was looking for a way to incorporate waste oil into the mix.
The wood fire itself is fairly hot already. With a stack temp of around 1000 degrees.
Could I just use an oil burner to somewhat atomize the oil and pump it into the firebox?
I know the oil burner itself would not ignite the oil, but the fire itself should? Right? Or wrong?
Any help and advice would be great. I should have a lot of wood stocked up by now, but I'm running way behind due to breaking my ankle last month. So I'm hoping to cut down on the amount of wood needed.
Re: Waste oil for my maple syrup evaporator?
« Reply #1 on: November 24, 2014, 08:04:06 pm »
I have a friend that uses an old oil pump to sort of drip oil into the wood furnace.  He gets rid of not so clean oil this way.  Im not sure how well it works though.  I would think it would be a good addition to the wood.
