Author Topic: Pid controller HELP! I have a REX-c100fko2  (Read 12528 times)
k7408
« on: November 14, 2014, 10:13:20 am »
I bought 2  REX-c100fko2 pids and i can not get them to work. One is for the preheater block and one is for the tank heater.
I dont know what parameters need to be set etc etc etc.. Im confused on how to get these working correctly. any help would be greatly appreciated. Thanks
Re: Pid controller HELP! I have a REX-c100fko2
« Reply #1 on: November 14, 2014, 12:49:40 pm »
Greetings!  I have never programmed this model before, but did you check out any of the youtube videos?  There are a few out there, but I'm not sure if they pertain to what you are trying to do with yours, but its worth a look:
http://www.youtube.com/results?search_query=c100fk02+
Normally with a PID, you just set temp and it will maintain it.  You need a thermocouple to read the temp and a heater of some sort, like a cartridge heater to produce the heat.  Think of the PID like a thermostat.
Hope this helps.
k7408
« Reply #2 on: November 14, 2014, 01:39:01 pm »
Thanks for the reply. I thought the same about the pid, just set the temp and done but it doesnt seem to work that way for me lol. I have a cartridge heater in the nozzle block with a K type thermocouple and a pt100 thermocouple with a tank heater in the siphon tank. Seemed simple enough?! The tank pid will not let me change the type of thermocouple in the settings menu and the nozzle block pid just flashes all small zeros on the top row (the pv row). Im going to keep watching videos and reading up on this. Ill post any progress if any as I get it.
