Author Topic: My Roger Sanders Waste Oil Heater  (Read 127080 times)
dngspot
« on: January 26, 2009, 02:23:39 pm »
1/7/09
I gave the MEN information to a couple of guys at work. We have an endless supply of used oil so why not make it happen. One of the guys has finished his unit. He did a 5 hour test run with a chimney sticking out the side door of his garage. It was 20 deg out and about 75 deg in the garage. His unit did not use the conical burner; he used a stamped metal pan. He also used a 4 inch computer fan to blow in the air tube. Over the five hours it used 2 gallons of oil. His tank is located above his heater off to the side. It is also attached to the heater. It also uses a simple needle valve for oil control. During the visit he never adjusted the oil flow.
I have started mine. I will be using a conical burner. I have pressed it from 1/4 steel. If it does not heat up enough during start up then I will go through the hassle and make one from aluminum. Tonight I stripped the hot water heater and cut a door in it. Then I noticed that I only have a 3 inch draft tube. Since Roger Sanders reduces his to 2 inch to slow velocity I will leave it alone. I will test it this way and if needed will still reduce it or weld in a 4 inch tube. I will also mount my tank similar to the unit my buddy made. I am hopping to have it finished by next week.
I hope no one thinks that I am hijacking this thread; I intend to show pics as I progress.
The burner.
The 40 gallon water heater tank with a door cut out.
1/8/09
I have not finished much; I picked up some hinge material (push tubes from a Cat 3406 engine). I am going to use a 30 lbs R134A tank for the tank that will be mounted above the heater. I have removed the handles and valve from the tank and silver soldered a 1/4 npt female fitting to the top of the tank. This will be the needle valve will mount. I also need to install the sight gauge and drill a 1 inch hole in the top for filling. Sorry I do not have any pics of this, the tank is at work and I am working at it on breaks.
I spent a little time on the heater. I cut the old draft line and mounted the burner. I also installed 1/4 inch npt plugs in five of the holes that were made by the hot water manufacture.
I am ready to start cutting and welding. The hole for the new 6 inch draft line still needs to be cut, the tank needs to be mounted and the door hinges need to be made and installed. I also need to install the frame on the inside of the heater door opening. I may weld this into place. Unfortunately I must do some garage cleaning to get to my mig and torches. I have been working on a few wood projects and need to move a bench and a few sheets of oak plywood. I will be working on this after work tomorrow.
Here are a couple of pics.
« Last Edit: January 26, 2009, 07:28:51 pm by dngspot »
dngspot
Re: Roger Sanders Waste Oil Heater
« Reply #1 on: January 26, 2009, 02:39:33 pm »
I have drilled 28 holes and mounted the door frame. I measured each side of the frame and found the center, then marked them. I did the same on the outside of the door. I then clamped the frame into place. I spaced 5/8 outside the door and drilled the center marks. Then put bolts in and tightened them. I marked every two inches and drilled for a bolt.
After the frame was in and tight it was not quite the same shape as the door. To fix this I used a 3 lbs sledge to beat it into shape.
The heater with the door.
The door removed.
I installed the hinges and welded them to the door. They are made from the handles of a R-12 Freon tank. The tank is the white tank I am using as my oil tank. They also are made from 3/8 inch bolts with the heads lathed down and the 3406 engine push tubes, as mentioned before. I used a piece of 3/8 round stock to align the hinge tubes.
Here is the pic.
It started well the door latch was coming together great. The door pulls tight and locks smoothly.
I bought a metal 5 gallon bucket from Sherman Williams. I have soldered all of the fittings for the drip system and level indicator. I like this thing better as it lets me remove the top for cleaning. The only draw back is I have to make a frame for it to sit on. The metal is even thiner than the R-12 tank.
I had a piece of 1/4 inch plate that I have been sitting on and it fits inside the lower lip of the new oil tank. So I welded it to the galvanized tube and the tank sits very stable on the plate.
The oil tank close up. The fitting with the plug in it is for the oil drip line. The plug was there for leak testing.
The complete setup less the pluming.
« Last Edit: January 26, 2009, 02:43:14 pm by dngspot »
dngspot
« Reply #2 on: January 26, 2009, 02:57:46 pm »
After its first run. I can put my hand on the top only for a second before the burning is too strong.
It was difficult to start only because the oil was so cool that I could not get a drip. This is out side with a strong wind. The wind is so strong that during heat up the flame would go out until I put a 2 inch reducer on the air intake. It seems burn better with it there so I will leave it.
I did not bring home the inferred thermometer but, it is hot. More testing is needed to see how it performs over the long run. I think I need to get it out of the wind so the heater keeps the bucket with the oil warm.
Here are the pics.
The stack and bucket. This shows how dark the exhaust is. Difficult to see and does not stink like burning oil.
The completed unit undergoing its first run. Look closely you can see a bit of exhaust.
After running for about 6 hours, this is what I have learned. It used 1 gallon of oil at high burn. The conical burner and air make the flame form a cone that hits the walls of the heater. The draw back of the conical burner is, at top burn it can overflow and make a mess at the bottom of the heater. My solution is to add a 8 inch cast iron pan under the burner. I cut a ring from the piece that I cut from the old flue and set it in the pan and then set the burner on the ring. It worked better than I thought it would. If any oil spills over, the oil in the pan catches on fire and heats the burner from below. One thing that is a drag, the pan too will need to be cleaned.
The heater gets dang hot and is fully adjustable from a high heat to a low heat. For some reason during start up a mess of coak floats on top of the pool of oil, I used a metal rod to move it off of the burner and then no more problems. Also during start up or when ever the door is open, the flame vortexes up the air intake tube but, as soon as the door is shut draft changes from the intake to the flue. Then the fire spreads out to the sides again.
The soot level is pretty high but this was expected. Oh yea, wind plays havoc on the flame. This will change when I get it inside.
I brought home a barrel and cut it to make the shroud.
Here are the additional burner pieces. The lower pan has not been cleaned.
This is the complete burner.
It is painted and ready for installation. Now I have to find a chimney kit at a reasonable price. Installing it will cost the most.
I used Caterpillar muffler paint for the project. When it cures it will be a little lighter than charcoal grey.
The heater.
The shroud.
1/24/09
Well it is not as warm as it was last weekend, 21 degrees. I wanted to show pics of the flame and the iron burner in operation. It was difficult to get the oil flowing. I am using old motor oil from our personal vehicles. It is very thick when it is this cool. With less wind it was easier to light. Here are the pics at medium burn. It is the best I could do with the oil flow under that temp.
The next pics are looking down the air intake.
The new aluminum burner, I will test this tomorrow. The first 1 inch from the out side diameter is cut at 10 degrees. The rest to the center is at 12 degrees.
1/25/08
The aluminum disk is a total waste of time. The flame would die as soon as I shut the door. The cast iron and steel burner is what I will use from now on.
I started when it was 18 degrees outside. I also put the heater in the in the shroud. The shroud works outstanding. The heater is at 700 degrees and the out side of the shroud is at 50 degrees.
A dampener is a great addition to the system. It makes starting easier. I just shut it to a small opening and less air is pulled in to cool the oil. As the oil heats I open the dampener a bit more. To keep the heat at its full potential I have been running it about 1/2 open.
I have been running this thing outside and keeping the oil flowing it tough below 40 degrees. The oil bucket cools pretty quickly. I think in the shop this will not be much of a problem as there is no wind, and the shop will warm, and warm the oil also.
Yesterday I went out and picked up a 5 inch chimney system, my buddy is using a 4 inch exhaust, so I think I should be okay. I have a few more parts to pick up; I need to go to a heating and supply store to get them. They are a 7 inch roof flashing and storm collar.
Re: My Roger Sanders Waste Oil Heater
« Reply #3 on: January 28, 2009, 10:02:48 pm »
Hello DNGSPOT,
Great writeup and pictures!  Thanks for sharing.  Looks like you have it burning pretty clean by the looks of the smoke stack.  I'm sure your writeup will help others.  Thanks again!
Kyle
  • next in line!
« Reply #4 on: January 28, 2009, 10:36:04 pm »
I'm sorry, but I know that in the picture he had it hardly burning, thats why it "looked" clean burning, the fact of the matter is that no matter what size Draft tube you have (mine currently has a 6 1/4" id and no matter how hot the plate is or how much air you give it, it can only draft x-amount, without a outside force of air and partical atomization, clean it will never be.
dngspot
« Reply #5 on: January 29, 2009, 07:08:09 am »
In that pic you see about a 50% burn. I was having trouble with the temp and oil flow. In the pics with the heater unpainted those are burning almost to the point the burner is overflowing. The amount of smoke is far less than the diesel engines that I work on day to day.
dngspot
« Reply #6 on: February 01, 2009, 08:08:57 pm »
…A busy week end. My wife had me install a storm door. Who would have thought that Anderson could make a simple project difficult and time consuming? It took most of the afternoon on Saturday.
Sunday was mine. I gathered up the remaining stuff that I thought I needed for the chimney. Yet still make half a dozen trips to the local home centers. I could not believe the simple items I needed are not at one store I had to go to both Home Depot and Lowe’s to complete the project. But it is done and I am happy it works.
The chimney drafts incredibly well, almost too well.  It is 12 feet long and is about 1 foot taller than my ridge line. I also installed a dampener in the stack. Starting is not as simple as it was in the back yard. I have to let the oil heat up with the door open for about 10 minutes. I also have to restrict the air intake longer or the fire will blow out. After every thing is heated I can control the air intake with the flue dampener. I am going to make a variable cover for the intake tomorrow.
I ran for about 45 minutes. I got it pretty hot and the paint started to smoke and smell. I tried to do this out side but could not because the weather was too cold and the oil would not flow.  It heated the shop pretty quickly but the temp outside was pretty warm today, 40 degrees.
I am eager to start tweaking it for my needs now that I have it functional inside.
« Reply #7 on: February 01, 2009, 08:18:14 pm »
Looking good!  Thanks for sharing.  Looks like you are going to have it nice and toasty for the rest of the winter.
dngspot
« Reply #8 on: February 03, 2009, 06:11:15 pm »
Thanks Russ.
The new damper is in and is working great. Start up was easy. As far as running it I just open until it starts to go out then close when the center of the puddle is stabilized.
Here are the modifications.
dngspot
« Reply #9 on: January 17, 2010, 02:44:37 pm »
By the time I finished the heater last year, winter was pretty much over. The heater did okay but I noticed when the fire was at its hottest I had to close the intake more. This was counter productive as it would lower the flame and the puddle would grow. This Christmas weekend I was working in the garage and we had a cold front move through that lowered the temps to 0. So I fired up the heater and went into the balancing act trying to keep the fire at peak and not smothering it with little air. I was becoming frustrated as I was spending more time with the heater than on the work I had to do, and the garage really never warmed up. During some of the adjustments I opened up the intake and noticed the fire would clear out from the center and turn white on the outer edges of the plate. I could also see a wall of smoke over the plate with just a inch of clear air hitting the plate.
The fix, remove the 3 inch tube and install a 4 inch tube just as Roger Sanders has in his. I finished today to just as the temps got to 50 deg, and lit it up.  What a difference a perfect flame no mater how much oil is fed into the heater. It no longer overflows because the oil burns before it can. Dang should have done this last year.
« Last Edit: January 17, 2010, 06:15:58 pm by dngspot »
pigpen52
« Reply #10 on: November 22, 2010, 08:47:41 pm »
Nice work.....I have a few questions... the mothers setup uses a top plate and middle plate on the burner...any reason why yours does not?   and again...why use cast iron skillet?  just more durable?   and...just so i am sure I understand....your fresh air intake is the one ducted to the outside while the exhaust from combustion is vented to the shop?  Oh...and How do you start it?
« Last Edit: November 22, 2010, 08:50:23 pm by pigpen52 »
dngspot
« Reply #11 on: November 24, 2010, 12:27:16 pm »
My version is not the original Mothers design; it is based on Roger Sanders heater.
The exhaust is not the pipe from just above the flame. It is a 6 inch pipe flush with the top of the tank to the side of the intake. The intake is located at the center of the tank and is just 8 inches above the burner. Air is pulled in from the 4 inch center pipe and pushes the flame out to the outer wall.
The vent is the flue and it exits through the ceiling and roof to about 1 foot over the ridge line.
The cast iron skillet is used to catch and burn any oil that might over flow the conical burner. I do not have this problem anymore but like the security. I tried to use the aluminum burner and like the steel one better.
I start the burner with a steady drip and about 2 ounces of BBQ lighter fluid. I have a small propane torch to actually give flame.
I have made a change to the drip system that makes it easier to see how much oil is feed to the burner. I will post detail and pics tonight.
Any other questions feel free to ask.
« Last Edit: November 24, 2010, 12:30:09 pm by dngspot »
dngspot
« Reply #12 on: November 24, 2010, 05:07:43 pm »
One thing I hated to do was to stand over the heater and look down the intake pipe to find out how fast the oil was flowing. During a search on waste oil heaters I found on YouTube a guy who built a Sanders design, he bought a needle valve with a window from Roger Sanders. He also posted he paid $50.00 for it. With a pic of the valve I began another search and found a valve made by Lube Devices and the part number was N102-02, It turns out that Grainger carries them under their number 1U795, they go for $34.95. This little guy makes setting the heater so much easier. I recommend highly.
ruddfan
« Reply #13 on: December 20, 2010, 09:17:34 pm »
Hi can you give me plans for your burner that you used
thanx
Herb
dngspot
« Reply #14 on: December 27, 2010, 02:37:19 pm »
Roger Sanders is no longer posting the plans. He is now charging a fee for them. If you follow my directions you should be able to build it. If you have any questions feel free to ask.
