Author Topic: OZZERT burner rules  (Read 9363 times)
OILHEAT
    • Daniel Tree Farm
OZZERT burner rules
« on: February 23, 2012, 10:21:51 pm »
Been a full winter and the garage was always warm when I needed it to be from the ozzert design oil stove.
All I could see from the chimney was some heat vapors, nothing elts. On the other end of the chimney was a hot, heat throw'n stove keeping me warm as I worked on different projects.
Watch the you tube vids, pay attention to ozzerts burn chamber 's' and build one just like that and it WILL make a lot of cheap heat.
THANK YOU OZZERT!!!
Used oil is beautiful
Re: OZZERT burner rules
« Reply #1 on: September 20, 2012, 03:49:22 pm »
Inquiring minds want to know:
  • What's your fuel consumption?
    How much space do you heat?
    How (good or bad) is your insulation in that space?
    How did you overcome build problems?
    What would be different, if you built another?
Thanks for the report, OILHEAT. ;D
