Author Topic: Lighting Oil  (Read 8567 times)
mjohnson2981
Lighting Oil
« on: February 06, 2012, 08:58:18 am »
Hello,
I have modified a Becket AFG to run on waste oil.
Here is what I have done:
* Changed nozzle from the rated .85 to .55 same pattern & angel (70* Solid)
* Added PID, thermocouple, and cartridge heater clampled around J-tube inside barrel
* Filter oil through a 10 Micron hydraulic oil filter and throught a RF-1 filter
* Turned pump pressure up to 135psi
* Operate PID at about 350*F
What I have found:
   The unit lights and runs fine but I plug nozzles like crazy. I understand that  I should run the temperature around 170*F. This is fine, however I cannot get the unit to light at 170*F.
Is there a differnt adjustment other than factory for the electrodes or another trick?
Any help is appreciated.
Re: Lighting Oil
« Reply #1 on: February 28, 2012, 09:48:20 pm »
You can turn up your heat to get it lit, but then turn the temp down.  Unfortunately this is a downside to a pressure type system.
I have also found that larger nozzles are easier to get started, but may put out too much heat.  Dont melt your furnace down!
