Author Topic: Where does the drip line go?  (Read 8751 times)
teched
« on: January 03, 2012, 08:26:53 am »
Found a useable 40 gallon tank.  Already had a door and flue hole cut.  I added 3" air intake hole and am going to weld in a piece of Drive shaft tube with the funnel on the end.  I rapped copper tubing around the 6" flue pipe 6 or 7 times and brought the tube to the center on the intake hole.  I am going to switch from copper to steal at this point thinking it will last longer in the heat of the stove.  My question is...  Do I run the drip tube stright down the center of the ait intake pipe, through the center of the top pan and through the center of the 1/4" steel plate down into the the bottom burn pan.  Or do I run it outside the burner assembly and poke it in where the fire comes out of the burn pan?
« Last Edit: January 04, 2012, 04:23:44 pm by teched »
