Author Topic: refrigerator type compressor  (Read 14072 times)
unabomber
« on: January 13, 2011, 07:17:00 pm »
Anyone tried one of these compressors ? I would like to know your findings before i cannibalize a fridge. similar ones can be found in window ac's freezers etc. I see them as being whisper quiet, reliable and capable of high pressures. The ? is about volume.  thanks in advance
steve
Re: refrigerator type compressor
« Reply #1 on: September 12, 2011, 11:52:37 pm »
these fridge compessors work awsome; im running a old one and it runs my sypon  nozzel burner. they work good.
« Reply #2 on: September 19, 2011, 09:24:51 pm »
Hmm... interesting.  Could these be used to transfer oil?  For example from my 55 gallon drum to a 5 gallon bucket?  I am not concerned about speed, but how many gallons per minute would one pump?  Are they self priming?
Thanks for the info.
« Reply #3 on: September 24, 2011, 02:42:17 pm »
already tried that, no they dont work they just gring to a halt as the motor isnt powerful enoughto keep it going, although pump would do it.
i use an old hydraulic pump, does it with ease
« Reply #4 on: September 20, 2012, 08:01:27 pm »
    My 8th grade "Science" teacher (over 40 years ago) used a reefer compressor as both a compressor and as a vacuum pump.
 - Jr. High Science is merely Basic Physics = introduction to how things of this world work.
    A friend used one with a tank to power his airbrush.  I am about to replace a bad air compressor on a medium tank with one.
    I saw one mounted on a smallish tank (maybe 2' x 1') in a garage powering a forge type burner some guy was building in a YouTube video.  No follow-up video, though, so no idea if it kept-up with demand.
    Yes, Russ, they be super quiet and efficient, too.  Most run 40 minutes of every hour, and cost only about $5 per month.    Sadly however, they are designed to pump substance in a gaseous state, not liquids.
O, well.  Onward & upward.
« Reply #5 on: September 20, 2012, 10:47:28 pm »
What kind of pressure could one expect from one of these compressors?
« Reply #6 on: September 26, 2012, 10:53:12 pm »
I'll ask next time Jeff calls from "out there on the Big Road," though I think we spoke of roughly 100+ psi on his system.
Where ever it tops, it's a somewhat less than spirited trip, yet plenty volume & psi to run an airbrush.
« Reply #7 on: September 27, 2012, 10:11:41 am »
Ahh yes, lots of people doing this on youtube.  I found this one interesting:
https://www.youtube.com/watch?v=9jOcLdZXRRs
Would this provide enough air to run a siphon burner system I wonder?
