Author Topic: Spikes Truck Drum Heater  (Read 25925 times)
dngspot
« on: December 27, 2010, 03:02:45 pm »
I have been able to get 800 deg from my Roger Sanders heater and want it a bit warmer. So I am giving it a go with a different design. It has cast iron drums and a better air intake than the Roger Sanders design, in my mind.
The first thing I did was obtain a couple of 16.5" brake drums from a large semi type truck. I put them on the lathe at work and machined the drums so the open edge of the drums would mate with each other.
Here is a pic of the lathe I used; it took about 2 hours to do both drums. It is also available to me during off hours at work.
The drum edges, they are orange looking because of the fresh rust. I kept these in the back of my truck for a week while I gathered parts.
The outside cut on the bottom drum.
A close up of the inside cut on the top drum. Sorry for the pic quality.
The cylinder after sandblasting and removing the bottom 2 inches, I believe it came from a C-15 Cat engine. I cut the bottom flat and inside of the cylinder with the lathe. I cut the inside of the cylinder about .020" because that area seems as hard as diamonds and does not drill well. The air vent holes will be in the lower 3" of the cylinder.
I cut 2 round plates to fit on the lug side of the brake drums. Both plates have 5- 1/2" holes for bolting. There are more holes, two for the bottom plate to fasten the cylinder to.
This pic shows the top drum with the second plate on top.
I will post more as I go.
« Last Edit: December 27, 2010, 03:04:56 pm by dngspot »
dngspot
Re: Spikes Truck Drum Heater
« Reply #1 on: December 27, 2010, 03:32:19 pm »
I cut another disk. It will set on top of the cast pot. The pot is the place the oil will drip into. The disk is machined so the cylinder will fit into it. The cylinder is about 6" O.D. The disk also has 5- 1/4" vent holes and a piece of steel welded to it, to help position the pot.
Here is the pot.
The bottom of the disk…
... and the top of the disk.
This is a pic of the burner assembly less the frame. The top plate will be bolted to the lower brake drum.
The frame has a spring and a handle to release the pot. The spring pushes directly on the bottom of a plate that the pot sets on. The plate is attached to a hinge that is welded to a cross member on the back of the frame. There are two dowels one for the bottom of the spring and one for the plate to keep it in place. The plate for the bottom drum has 1 inch spacers for bolt clearance, welded to the frame. The drums setting next to the frame are setting as they will once the frame and drums are mated.
I need to widen the front of the frame; it is difficult to clear the pot. I also need to drill the cylinder for vent holes and install a baffle in the drums to deflect the draft out to the drums. Then I can weld on the draft tube, paint and install.
« Last Edit: December 28, 2010, 07:46:30 pm by dngspot »
dngspot
« Reply #2 on: December 28, 2010, 11:34:54 am »
This morning I went out to a very cold garage and cut off the front of the stand. I built the front of the stand 2" wider than before. In the pic I put most of the heater together for a quick view of what the dimensions are going to be. To the right and about 15 feet behind is the Roger Sanders heater I built a couple of years ago. I ran it up to 500 degrees and could still see my breath after 2 hours. Nothing is fastened together in the pic.
The remainder to finish the project.
1. Build and fasten a couple of brackets to hold the pot lid to the cylinder.
2. Drill into the pot lid and build or assemble a connector for the oil line. I will use 3/8" copper or steel line.
3. Drill the vent holes in the cylinder.
4. Drill the pot to accept all thread for a handle.
5. Install a piece of angle iron in the pot to direct the oil to the center.
7. Test out side
8. Clean and paint then install.
« Last Edit: December 28, 2010, 11:38:29 am by dngspot »
« Reply #3 on: December 28, 2010, 02:51:10 pm »
great thread, nice to see your approaching this at a different angle
« Reply #4 on: December 28, 2010, 08:17:52 pm »
Spike's heater is what I was going to build as my first burner. I had started to collect some parts. Then I had change of mind and went with the ckBurner. Nice to see someone building a Spike's. Thanks for sharing.
dngspot
« Reply #5 on: December 31, 2010, 07:31:34 am »
I did more. I welded a plate to a piece of angle iron, and then drilled 1/4" holes in the pot to bolt the angle iron assembly to. I also drilled a 1/2" hole, for all thread, to use as a handle. Then a piece of 1" pipe over the handle and a nut to keep the handle tight.
The cylinder was drilled with 38- 5/16" holes and two tabs were added. The tabs fasten to the pot lid, so when the pot is removed I do not have to fiddle with the lid.
I did not post a pic of the plate the pot sits on. Again it has a spring attached to under it and uses a standard hinge.
The lid for the pot was drilled and taped to 1/2" pipe. I made tube connector from a 1/2" pipe nipple and cap. The nipple and cap were drilled a 3/8 bit.
I built a baffle from a piece of scrap. It hangs from the top about center of the drum assembly. The baffle is about 12" wide
I painted and placed it in the old heater heat shield.
I did a test run with about a quart of oil in the pot. The heater smoked out of the pot lid 1/4 inch holes and when the oil came to temp flames came from the cylinder holes. There are about three things that I can change to fix the problem. The first would be a problem with the baffle. It was a design that I thought up not one that Spike uses. The second would be, my chimney reduces to 5 inches. I may have to put in 6 inch pipe. The third would only affect the smoke, I have too much vent in the pot lid, air could be coming in from between the lid and pot. I could install temporary bolts in the vent holes and see if the lower pot continues to get enough air but does not smoke.
dngspot
« Reply #6 on: January 01, 2011, 07:47:52 am »
Yesterday I installed a 6 inch chimney. The thing continues to flame through the holes at high burn. I did open the pot during a low burn and noticed the flame would increase when this was done. This leads me to believe there is not enough air making it to the flame. One thing I will note, the chimney did give it a wider burning area before the flames come out of the holes in the cylinder. My next move is to drill more holes in the cylinder.
I also built a shelf for the bucket and plumbed in the oil line.
unabomber
« Reply #7 on: January 08, 2011, 04:10:01 pm »
i made one of these heaters for my 1700 square foot shop. been usng it for two years can offer  tips if you want
dngspot
« Reply #8 on: January 11, 2011, 02:09:29 pm »
Feel free to give those tips.
I have drilled two more rows of holes. With the same problem. I think it is because of air leaks between the pot and the lid. I have a bettere quality pot that I will be using. More work this weekend.
unabomber
« Reply #9 on: January 11, 2011, 07:51:21 pm »
some of  the buttons on my computer dont function. so may be hard readng.
there should be no to very little oil in the pot. except just after start up and thats only because its not up to temp.  up to temp is around 400 plus degrees on the bottom of the pot or pan. i use half a cup of gas to get mine going and light it fast so no fumes buld up .
 running properly it should burn as fast as it drips in.  the tric to ths burner ...draft  ...seal any holes that are past the cyl liner even up the stac 12 feet or more of 6 " is about minimum. . i run about 20 feet of 6 " all seams taped w exhaust wrap.
 i also found the deep pot a challenge to run so  got a shallow pan of the same size and its great easy lighting.
mine puffs out the holes in the cly  when first firing cold .. too much fuel .. low draft or a restriction in the stac
the 5 or 6 holes in the lid are plenty you dont want too much more than 5 or 6  5/16 holes or the ash wll be hard to remove.and may not be a clean burn  also must be close to air tight to the pan. or less holes
the amount of holes in the  cyl and where they are placed maes a huge difference. close to the bottom heats the pan better further away less. deep pan more holes closer to the bottom . i haved a mx of small holes on the bottom and larger ones up top. the amount of holes and size in the cly liner dictate how much oil you can burn.  more holes more oil ...... hope ths helps
dngspot
« Reply #10 on: February 13, 2011, 09:36:35 am »
I have not done anything with my heater since early January. Now that we have had a break in the weather and out of the below 0 temps I did some more today.
I think I am getting closer to a workable heater. Today I took the pot, lid and cylinder to work to do some work. I made new brackets for the cylinder and lid. I noticed when I took them apart one of the brackets was holding the cylinder above the lid about 1/16 inch. I also obtained a large piece of sand paper that had an adhesive side and stuck it to a flat bench. I then took the pot and surfaced the top edge. That sucker is flat now. I took a light around the lid and pot from the inside, and could not see light from the out side of the pot. The biggest problem was actually my spring and hinge design. I noticed when I put the freshly surfaced pot into place I could pull the handle up and the front of the pot would lift about 1/16 inch before it would make contact to the lid. I placed a 1/2 inch spacer on the front of the hinge assembly under the pot and that did the trick. I will weld a proper spacer to the hinge later.
I lit the thing and brought it to temp. It made a couple of humming noises, this is what it did before it would throw flames out the secondary burner, and there were no flames this time. This may be because of the larger holes I made in the lid for the pot air intake. I will eliminate 2 of the holes until I have the time to weld them and re-drill to ¼ inch.
The hottest I could get the thing was 380 degrees at the top plate near the flue. The drums reached 300 and the pot was hanging around 800. All temps were taken at the top burn with a 1/4 inch pool of oil in the pot.
It was tough to light and this may be due to the amount of holes in the secondary burner, as per Spike. I plan on buying bolts to fill the 50% of the holes.
The exhaust was very clear, all I could see was heat waves, no smoke during all burn levels.
Over all I think things are moving in the right direction.
dngspot
« Reply #11 on: February 13, 2011, 12:18:40 pm »
I plugged half of the holes, this is not the answer. The secondary burner threw out flames very quickly after start. The pot was under 400 deg. Now that I have all air leaks pretty much covered I wonder if the problem could be the diameter of the cylinder. I have access to three 4 inch cylinders but this would mean making changes to the lid and lower drum plate. I think I might contact the builder, Spike, and take his direction.
This time I managed to get a couple pics of the secondary burner when it is failing.
« Reply #12 on: February 15, 2011, 02:00:59 pm »
looks like too much oil is trying to be burnt, on my drip feed system i have an air inlet further up by the start of the chimney/stack so its not sucking too hard from your secondary air souce, unbolt the stack and put washers under the bolts and try that, it would help with the draw and let air in
