Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Search
Login
Register
Waste Oil Heater
User Projects & Pictures
Dead Eye Lil Gun
« previous
next »
Print
Pages: [
1
Author
Topic: Dead Eye Lil Gun (Read 19814 times)
Dead Eye
Gettin' the fire started!
Dead Eye Lil Gun
on:
December 19, 2010, 09:38:18 pm »
Well here is the start on the lil gun. A conversion to a Wayne burner using a Craig Kepner (ckburner) kit.
The first mod is to extend the air tube (blast tube) to hold the preheater and a hole in it for the fuel line.
A Kagi retention head.
A spring added to top of preheater block to hold center
The PID temp control to left side
Last Edit: December 19, 2010, 09:52:25 pm by Dead Eye
Logged
Administrator
Master Oil Burner
Re: Dead Eye Lil Gun
Reply #1 on:
December 20, 2010, 06:01:09 pm »
Lookin good. Keep up the good work!
Logged
Dead Eye
Reply #2 on:
January 01, 2011, 04:24:41 am »
Started the Combustion Chamber~ Built of 10 inch pipe inside a water tank.
No pics yet but a drawing I made.
Logged
Dead Eye
Reply #3 on:
January 01, 2011, 04:09:05 pm »
Started construction of the combustion chamber, It is a piece of 10” pipe with ¼ wall thickness 4.5 feet long. The burner end has a mount ring tack welded to it 10.5” diameter with a 4 ¼” hole for the burner air tube (blast tube) other end has a flange with blank off plate for cleaning out.
First try yielded a nice looking flame burning old soy bean oil but after shut down it was found that the inside wall off the pipe was wet with oil so I will construct a smaller inside pipe (burn tube) to hold the pattern together.
Logged
Dead Eye
Reply #4 on:
January 28, 2011, 07:42:36 am »
Getting it together
I build this way for easy clean out.
Last Edit: January 28, 2011, 07:44:25 am by Dead Eye
Logged
Administrator
Master Oil Burner
Reply #5 on:
January 28, 2011, 11:12:12 pm »
Very interesting. Cant wait to see how it works out for you. Lots of custom stuff out here, but mostly drip style. Thanks for sharing!
Logged
Dead Eye
Reply #6 on:
January 29, 2011, 04:02:18 pm »
Burned a half quart of WVO in it today and it has the dreaded wet chamber. Will make a burn tube soon.
Logged
steve
Reply #7 on:
February 02, 2011, 10:17:20 pm »
Hi Dead Eye
do you have any pics of the nozzel your using, im kinda lost how this sypon system works, or is there any detailed pic on this website Thanks Steve
Logged
Dead Eye
Reply #8 on:
February 12, 2011, 09:00:08 am »
Hey Steve, sorry for the oh so late reply Iv not been on here for a few weeks. There are a few pics at the top of this thread. Its the brass piece screwed into the block. You can google delavan siphon nozzle or hago siphon nozzle to see the other end. It has a stem with o ring on it.
Logged
steve
Reply #9 on:
February 13, 2011, 11:59:11 am »
Thanks Dead Eye, i ordered a pre heater block and nozzel from ck burners,also a pid and retension head, how did you make out with yours is it up and running now ?
Logged
Print
Pages: [
1
« previous
next »
Waste Oil Heater
Dead Eye Lil Gun
