Author Topic: let the fun begin  (Read 110204 times)
superduty_59
Re: let the fun begin
« Reply #90 on: December 19, 2016, 08:26:56 am »
Doug I thought I read that your system is a closed system. Do you have a water line trenched to your boiler to add water when it needs or a ( I know they make automatic valves to refill)? Do you only have one zone? Do you use your boiler to heat your water tank too? How many pumps and what brand size, ect. (for example Taco 007). Thanks
Doug, I just went back through some of your thread and found the answers to some of my questions.
1) is the boiler pipes and water suppy trenched below frost line?
2) do you have a mixer installed ( I have read that especially with cast iron boilers the return needs to be mixed with a little of the supply to prevent boiler shock)?  Thanks
« Last Edit: December 19, 2016, 09:31:50 am by superduty_59 »
« Reply #91 on: December 19, 2016, 07:16:49 pm »
the boiler pipes are buried 4' deep with a foot of sand surrounding them for protection. water supply is connected feed pipe coming in to basement.  once the system is charged there is no place for water loss of any volume, it is closed system.
superduty_59
« Reply #92 on: December 20, 2016, 05:49:57 pm »
Thanks for the reply Doug! So in a closed system you really do not need to add water.
« Reply #93 on: December 21, 2016, 03:33:27 pm »
I didn't say that.
superduty_59
« Reply #94 on: December 21, 2016, 05:53:02 pm »
ok, still learning about the different devices ona boiler system! Thanks Doug.
« Reply #95 on: December 21, 2016, 10:38:07 pm »
I think Super was just asking the question about mixing the water to prevent boiler shock from too cold of water coming back in.  I have heard that before, but dont know if there is any truth to it.  I have a small water heater inline that helps with thermal storage and probably would help with boiler shock, but my return line never gets that cold.  I would imagine if you had a larger heat exchanger, or several, or a sidearm on your water heater, it could bring the temp down.  A friend of mine has a sidearm on his water heater and he says that running the hot water in the house can drop the boiler temp in a hurry.
superduty_59
« Reply #96 on: December 22, 2016, 07:43:03 am »
Yes Russ, I have read that if you have 180* leaving your boiler you should not have more than 10* ( have read varying temps from 10*- 20* so...) difference in your return. With a mixer /bypass it take some of that 180* water leaving the boiler and t's off like a zone but feeds back to the return to the boiler so it tempers the return water so you don't get "Boiler Thermal Shock". Like I said I'm far from an expert and I am still learning and don't want anyone to have a short life for their boiler.
« Reply #97 on: December 22, 2016, 08:35:47 am »
water supply trenched below frost line
you have me confused. you asked about my domestic water supplying the boiler system. then you ask about boiler shock with a mixer valve in the supply line. no mention of the mixer being in boiler supply line.
I have no temperature gauge in the return line to the boiler.
I say this with all kindness "it is possible to over think a project".
« Last Edit: December 22, 2016, 08:39:04 am by doug »
superduty_59
« Reply #98 on: December 22, 2016, 08:47:38 am »
Doug I was asking 2 different questions. :D
1) about water suppy for adding to the system when needed and
2) mixer for boiler shock prevention installed in the (boiler out supply to your house)
I only have a crawl space like Russ. I was trying figure out if I needed to run a water line (below frost line) out to my shed or I found out by asking you which I never thought of that I could just add water as needed right in my crawl space and not have to run it to my shed.
« Last Edit: December 22, 2016, 08:53:23 am by superduty_59 »
superduty_59
« Reply #99 on: December 22, 2016, 08:52:15 am »
I have another question. What would happen if your system stopped working for some reason or you ran out of oil or you didn't want to leave it unattended while on vacation. Is your system well insulated to avoid freezing? Do you have to have alternative heat in your shed? Would your heat exchanger back feed heat back to your boiler in the shed?
Thanks James
« Reply #100 on: December 22, 2016, 08:56:16 am »
my neighbor hand dug his water lines from the boiler to his house. I don't think they're over 2 feet deep. I'm sure he insulated them well.
« Reply #101 on: December 22, 2016, 09:07:43 am »
Thanks James
I had that issue on cold night. I'm sure that when you get your system up and running and when that happens to you, you will be able to figure it out.
superduty_59
« Reply #102 on: December 22, 2016, 09:24:15 am »
Thanks Doug! I guess I'm a perfectionist. I have had trouble over the years starting or completing projects because if I can't work out all the little details in my head first it doesn't make sense to even start. My dad alwals says do something even if it's wrong. Appreciate the help!
« Reply #103 on: December 22, 2016, 12:45:48 pm »
If you are running water in situations where it could freeze, would it just be a good idea to use antifreeze to avoid any freeze up problems?  If your pump is running 24x7, yes, I would think the exchanger would keep the water warm from your other heat source preventing a freeze up.
superduty_59
« Reply #104 on: December 22, 2016, 01:42:05 pm »
Well there you go Russ. I don't know a lot about these closed loop systems but that certainly sounds like a good idea running anti-freeze.
