Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Search
Login
Register
Waste Oil Heater
Waste Motor Oil
let the fun begin
« previous
next »
Print
Pages:
1
2
3
4
7
Author
Topic: let the fun begin (Read 129018 times)
Can't stop the fire now!
Re: let the fun begin
Reply #15 on:
November 26, 2011, 07:22:21 am »
BTRAPR,
I could never find a how to book. I spent a lot of time surfing the net for information about heating with waste oil.
"Waste Oil Heating Forum" is one of the sites I found. Other sites that where very helpful to me. The first one is
http://www.garagejournal.com/forum/showthread.php?t=24280
" this shows how he converted fuel oil burner to burn waste oil. He also gave out some part numbers that he used in his conversion. The other site is
http://www.ckburners.com/
". I got my heater block, nozzle and heater cartridge for him. There's a lot of information on this page about converting to a waste oil burner. I suggest buying this kit. It will help reduce your learning curve on what works and doesn't. Craig will also help answer question. An other site with lots of information is "altfuelfurnace".
Good luck with your project and please keep us updated on your progress.
Logged
Administrator
Master Oil Burner
Reply #16 on:
November 27, 2011, 10:16:53 pm »
Yes, the yahoo group altfuelfurnace is a nice resource that seems pretty active. I was hoping some of the folks on that forum would venture over here as the yahoo layout is sort of confusing. It's certainly worth checking out though.
Logged
Reply #17 on:
January 01, 2012, 03:19:07 pm »
been heating house and garage since mid november with the waste oil/boiler set up. topped the tank off today with approximately 200 gal. the hour meter reads 391 hours that the burner has run. so when the burner is running it's burning close to a half gallon an hour.
Logged
Administrator
Master Oil Burner
Reply #18 on:
January 01, 2012, 10:08:47 pm »
That's awesome Doug. I'd say you have a successful build.
If you have more pictures to post, but are having troubles getting them re-sized and posted, just let me know and I can do it for you.
Thanks for the update.
Logged
Reply #19 on:
January 01, 2012, 10:57:11 pm »
russ,
i haven't taken any pics of my new set up. just waiting to see how well it works before i show it. may be this week i'll try and get some pics.
Last Edit: January 26, 2012, 09:19:59 pm by doug
Logged
Reply #20 on:
January 02, 2012, 06:53:37 pm »
from january 2006 till the spring of 2011 we heated with a corn boiler. insulated underground pipes and heat exchangers were in place. just remove the corn boiler and set the shed back in it's place.
Last Edit: February 17, 2012, 11:47:14 am by doug
Logged
Reply #21 on:
January 02, 2012, 06:58:27 pm »
this is our waste oil boiler shed. found this used 10' x 10' shed on craigslist. after putting insulation, drywall, a coat of primer and it was ready for the boiler.
Last Edit: January 06, 2012, 08:27:14 pm by doug
Logged
Reply #22 on:
January 02, 2012, 06:59:42 pm »
an inside view of the waste oil conversion boiler shed. a buderus g115 4 section boiler was an other craigslist find. the thomas 2650 air compressor came from ebay.
Last Edit: January 26, 2016, 04:41:35 pm by doug
Logged
Reply #23 on:
January 02, 2012, 07:00:52 pm »
timer counts hours the unit runs.
Last Edit: January 02, 2012, 07:27:18 pm by doug
Logged
Reply #24 on:
January 02, 2012, 07:04:11 pm »
burner unit. now has a soleniod valve in the fuel line.
Last Edit: January 02, 2012, 07:28:38 pm by doug
Logged
Reply #25 on:
January 02, 2012, 07:05:30 pm »
barometric damper.
Logged
Reply #26 on:
January 02, 2012, 07:07:17 pm »
water temp and pressure gauge.
Logged
Reply #27 on:
January 02, 2012, 07:09:04 pm »
temp in shed stays 75* or high with burner running.
Logged
Reply #28 on:
January 02, 2012, 07:13:10 pm »
metering pump came from
http://www.centralohioheaters.com/Parts.html
. no need for a constant level tank now.
Last Edit: January 06, 2012, 08:26:20 am by doug
Logged
Reply #29 on:
January 02, 2012, 07:14:53 pm »
450 gallon fuel tank stays warm inside the shed.
Last Edit: January 06, 2012, 08:36:22 am by doug
Logged
Print
Pages:
1
2
3
4
7
« previous
next »
Waste Oil Heater
Waste Motor Oil
let the fun begin
